z287mgte;2011552 said:If the injectors are not firing then, cps ,
morganson;2011663 said:However if it so happens to cross talk to the Ne it will spark but you will not have injector pulse. (But will still have power)
morganson;2012386 said:Can someone tell me what this B1 connector goes to.
http://www.supramania.com/forums/sh...ta-Supra-Turbo-Body-plug-Pinout-s-with-colors
also pin 17 has continuity to the 12v B/o wire (pin 12). Is it supposed to have a little continuity or not?
jetjock;2012595 said:B1 goes to what it says in that link although the TEWD is a better reference that should be consulted instead.
17 should have continuity with 12. Again, the schematic makes that clear.
"A little continuity?"
3p141592654;2012685 said:Note that there is a tap on the injectors for the supermonitor for pre-89 cars. Used to compute fuel consumption. Also note that the TEWD on Cygnus for a 90 does not match exactly the link for an 88, so things change depending on your year.
I suggested a test in post #4. Did you do it?
morganson;2013122 said:But. I have 0 adjustability at all. Advance or retard just a little bit it dies like you flip a switch. For the record it now has a brand new igniter, and has been tested with all 3 ignitions and no difference.
Ill just leave this heremorganson;2013122 said:Cams are dead on, crank is top dead center. Cps is right in so whats up?
Thoughts?
