So you " re-pinned " the b1 m1 b2 b3 connectors?
Here check this Bud
B1 plug is that huge square one that is where your FUEL* issue if you re-pinned it would be:
1. A/C Water valve VSV MA7, Needs wiring transplant. Vacuum switch is at the firewall. - Black Yellow
3. Fuel Pump signal for check connector - Black Red
4. Circuit opening relay coil - Green
5. A/T coil for circuit opening relay- Black Blue
6. Fuel pump control relay . -Yellow
7. Plus for circuit opening relay- Black Red
8. NSW to cruise control clutch switch (MT) Delete, EA1 pin 3??- Black Yellow
9. Ignition switch- Hyb, ignition power supply- Grey/black Orange
10. To neutral start. Switch- Black/White
11. From A/C amplifier Hyb, for Idle Up signal -BLUE/RED
12. Theft deterrent horn signal ( can Delete )- Yellow/Blue
13. A/C water temp switch MA7, sensor needs transplant - Light Green/RED
14. ignition On- Hyb, +12v for ignitor and fuel injectors etc. - Black/Orange
15.SPD signal for cruise control-SPD signal for ECT-MA7, the speed sensor will stay in the car - Red/Green
This car was an auto wasn't it, or is it still? That white plug you have there is mostly for the automatic transmission, those don't have anything to do with the fuel.
