Seems like every tuner car except the MKIII has an aftermarket Electric Water Pump available. Someone please prove me wrong.
CRE said:What's the benefit of switching? Other than just moving things around under the hood for cleanliness.
encomiast said:The main benefit of an electric water pump for our cars in my eyes is the ability to keep it running for a few minutes after engine shutdown, so the coolant keeps circulating and cooling the cylinder head. The coolant getting too hot after shutdown seems to be one of the major reasons for BHGs...
But this can also be done with a small additional water pump, like many people have done.
bigaaron said:Full cooling capability at any engine rpm?
tte said:Why didnt Toyota design the block and the cooling system so that cold water enters the first 3 cylinders and the 2nd 3 cylinders simultaneously?
This way the block is cooled better.
With the current cooling system design, by the time the water gets to the last cylinders the water is already warm and less cooling occurs.
I cant remember if there is a car with this cooling system design?
Cheers,
Roy
