Poodles;1697553 said:
EGR will get better milage. Less oxygen and fuel used during cruise means better fuel economy. That's where the less fuel and advanced timing with the ECU tuned for EGR comes from.
The only way to do the same thing is with cylinder deactivation.
There is another way to deliver less oxygen and fuel in cruise...................
Less throttle activation and proper gearing. You cannot introduce a percentage of burned hydrocarbons into the intake stream and increase the BSFC of an engine. That engine, any engine, wants two things to operate, fuel and oxygen. Anything else is at best dead weight and at worst a detriment.
You're talking around my point and I think you know it. You're talking about pulling the EGR off an engine that is tuned for it and comparing that to one with EGR that's tuned for it. That is not the point.
EGR was developed to lower emissions. That's why it exists. It introduces contaminants into the intake air. It raises intake air temperature and lowers EGT. Anything that is not oxygen makes the engine less efficient. The engineers have had over 40 years to make a silk purse out of a sow's ear and have done a remarkably good job of it all things considered but they would much rather not have to deal with it and if not for emissions, they wouldn't be.
The same argument can be made now for injecting urea into the passenger diesel engines (and soon to be class 8 trucks). It's necessary to get them through emissions. Right now it's an exceedingly kludged up system, but it will get better in time. Even though it will get better it will never be as POTENTIALLY efficient as an engine that doesn't require the system.
If it's a fact that EGR will increase mileage in two mechanically identical engines, one tuned for it and the other tuned without, then there must be reams of SAE papers that verify that fact. Care to post a link to them? You won't find any. What you will find is papers that show that an engine that has had EGR removed will get worse mileage, something I agree with, but that's not the point.
Regardless, I'll let this drop as it's taken the thread far from the original question.
Which reminds me..........on the race cars I don't use a gasket, or a back plate. I drill and tap for an NPT plug, 3/4" NPT IIRC.
John Stricker
Russell, KS
