eFFeT's Swedish Powered Supra MKIII
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
I love what youve done so far, it all looks great.I really think if your successful with the intake plenum youd have a niche market if you ever needed to make a little coin on the side.Looking forward to seeing more progress pics.:icon_bigg
miekedmr
mkiii in hibernation
Jul 12, 2005
513
Upstate NY
amazing work
heh, no one is willing to give up the "little coin" that the manifold is worth really worth, I'm sure...
effet
73
Sweden/Arvidsjaur
IJ.;1072688 said:
Very nice!
Have you measured the plenum/runner volume yet?
Nope. Not yet. I can do it next week if you wanna know.
theKnifeArtist;1072999 said:
great build!
so is it gonna be an open or recirculated wastegate? or are you gonna put somekind of a throttle flap there inbetween the joint points to switch it from open to recirculate on sunday mornings?, hehe
I'm going to start to mount it as an open wastegate. And when I get bored with all the noise I might mount it to be recirculating. If I get bored will say :icon_razz. No falps or anything, I have to change it manualy.
effet
73
Sweden/Arvidsjaur
Hehe.. that would be nice. But I dont think anyone is willing to pay for all the man hours thats behind all the work.
effet
73
Sweden/Arvidsjaur
effet
73
Sweden/Arvidsjaur
Wohoo!!! I can only say one thing, it's ANGRY!!
Fixed the missfiering by changing the elektrod gap to 0,55mm.
But I have some heavy heating problems... driving at WOT in 10 sec will make the car overheat. :(
Other than the heating problems it runs fine. Boosting 1,5bar (22psi) now and climbing.
I almost shit my self the first time trying the car :D! hehe
No problem making the tires scream by just pressing down the throttle in third gear! :icon_twis
And the new intake is amazing! I had to rich the whole map by 15-20% to keep the same lambda as when I was using the stock intake and stock exhaust manifold.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
DAMN. that's amazing.
did you say you'd dress up the plenum? i think it looks cool like it is...
yay for progress! :D I also can't wait for a vid.
How many 7M-GTTE's are there out there? this is sweet...
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
Poodles;1088126 said:
stock radiator + no shrouding + lots more HP = overheat...
He has twin thermos with a fan shroud to suck the air through which should be sufficent enough to not overheat, unless the radiator's a bit stuffed or the thermostats not opening properly.Remember he is wot for only 10 sec.
Sir_2jza70
Sock puppet master
May 10, 2005
53
Canberra, Australia
Awesome project! :D
Considering the A70 is such a heavy car, making an inlet manifold out of CF is an interesting choice, but damn its awesome!
PS. I think your heat problems are coming from the FMIC being so close to the radiator. A friend of mine had a very similar setup (but around the other way) he had endless cooling problems until he eventually fixed it by spreading them apart further. Only need 100mm or so for it to be effective.
Having that oil cooler heat exchanger in your water line probably isnt going to help either.
Infact youve got quite a few modifications adding heat to an otherwise stock cooling system, no wonder youre having trouble!
