Eeeeevil oil leak
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
Ok so I've replaced my cam seals, front main seal, and my oil shaft seal, yet I STILL have a drip coming from inside my timing case, any ideas anyone?
Suprapowaz!(2)
2,870
San Antonio, Tx.
Did you put FIPG in the areas around the front of the cams?
Backlash2032
1,823
Nebraska
Grim, wouldn't that leak in between the block and the timing case? Not into the timing case?
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
