I'm looking for an ECU for my mkIII 7MGTE that will allow me to have true traction control and that will allow me to control the automatic transmission.
I was thinking of using an AEM but then I'll need separate traction control and a separat automatic transmission controller. All those things ad up.
Would it be possible to have all those in one? I think the motec will do it, but it is expensive. Are there any cheaper but just as good alternatives?
What would be the cheapest Motec model that will allow me to do the things I want?
Cheapest MoTeC, M600 unless you want to run the M400 in batch fire mode. Keep in mind that short of the M800/M880, you will not be able to assign unused ignition/injection channels to aux outputs.
