ECU rev limit crystal modification.
turbobob
196
Near Detroit
amichie;1290446 said:
I have done this on a few 7M-GE cressida ECUs. Does your ecu have two boards or just one? I have seen early model supra ECUS with just a single board.
I have modded around 100 3000GT/Stealth ECU's with great results.
The mustang guys used to do this before there were chips for those cars.
Just raise the crystal frequency 10-20% and re-tune.
It appears that some Supra ECU's have more than one crystal, I think they all should be overclocked by the same % unless there is informatuion to the contrary.
B
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Good luck with this.
The following sensors are sensitive to the internal ECU timebase:
AFM,
vehicle speed,
RPM,
although not obvious, also all A/D sensors (water temp, air temp, voltage, TPS, oil pres, internal reference) will be scaled due to the way data is transferred internally from A/D).
Internal 1 MHz serial comm will also be scaled between certain chips, possibly leading to data errors.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
There is also another crucial area it impacts that I forgot to mention, which is injector duration.
To fire an injector bank, the ECU computes the duration in microseconds and loads a timer interrupt counter. The timer clock is supposed to be exactly 1 us, so that the computed duration loaded into the counter is exactly the duration in microseconds.
Scaling the timebase will directly scale the injector duration, so a 20% increase in crystal frequency will results in a 20% decrease in injector duration. The fuel trims can compensate for some of this during closed loop calibration, but as we know, a 20% offset in the fuel calibration is a huge trim.
