ECU Chaser?
nestor bouboule
12
Cherbourg
Hello as I said in my presentation I am in the process of swapping a 1jz I have the engine and faisceu going on a jza70 but the ECU it is not good. I would like to know if there is opportunity to save when meme :1zhelp:
Thank you in advance for your answers against a no words too complicated please because my English is very limited lol:icon_bigg
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
whats wrong with the 1jz ecu? there might be local shops that could repair the circuit board for you
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Vous pouvez ou trouver des autres ECU ou employer un de l' Aristo ou MKIV Supra. Il y a de fortes chances que les condensateurs peuvent être remplacés, essayent un atelier de réparations local de télévision.
Thought babel fish might help out a little bit more.
tlo86
Jul 24, 2005
3,914
Colorado
too bad aristo is a french word too Lol. you could use a 2jz ecu but you would have its limitations as well
c_ronius
1jz 4Runner
Jan 2, 2007
109
Tampa, FL
www.rsworld.com
Looks like you have a Supra harness and a Chaser ECU. You will need to:
a) Get a jza70 ecu and plug it in.
Or...
b) Get the connectors for a Chaser/Soarer ECU. Splice them into the appropriate wires, then plug your Chaser ECU in.
Good luck.
nestor bouboule
12
Cherbourg
Cya;1026312 said:
OMG. How about I have a SUPRA ECU and a SOARER harness. We Need to talk!!! ASAP! I'll get pics as soon as I can!
It can be exchanged if you still want to see the coup total port is not heavy but it should not be very expensive:icon_bigg
