SupraDuty;1436187 said:
I don't get any text displayed for things like the station identifier and artist/title info like from RDS information...also when I play a CD I don't get any text for that either. I thought that most current head units had this ability and never asked about it up front, shouldn't it display these things? I see on other's pictures of the unit that it's showing artist/song info but not sure if that is from mp3's.
It does IF the CD is coded for ID3 tagging. Older CDs won't, but most newer CDs will do this. Also, there is a display setting for ID3 tagging, in which you hit the "DISPLAY" button when the radio is set at the normal text display. In other words, no graphics.
It also should display those stations set that way. I think the same "DISPLAY" button will need to be set to show the RDS stuff as well. I haven't played with that feature yet.
The bluetooth audio works but I can't seem to change albums, I have to go to the phone and start an album, then I can skip through the tracks and pause but can't change albums. Has anybody got that to work?
Another feature I haven't played with yet. It does support nested albums and nested searches, either by song, artist, or album, but the most I've done with my Ipod is set it at random and just let it play.
I got the phonebook to download(took a while to figure out) only to find that it can only store one phone number per contact so when I looked up my girlfriend's name it only had her home number in the list, not her mobile. Not exactly a question but just for others info.
Yup, ran into that as well. Changing the name by adding a few characters will fix that, but it's annoying.
Plugged the USB into my girlfriends iPhone 3GS, my old 4 generation iPod, and my son's Zune and couldn't get it to play anything. It recognized the iPhone as an iPod but never did play it. I've read that some have got this to work with the iPhone without ordering the "special" direct connect cable but doesn't seem to work for me.
Really? I got it to work with an Iphone, a Zune, Ipod Video, a 2GB flash drive, and a Nano without fail. The only thing I couldn't get it to work with was my 500GB USB drive, but that's because it didn't have an independent power source, and I think it's got too much on it to read the drive directly anyway.
There's also ANOTHER manual for the headunit that describes the features in more detail, like the Bluetooth phonebook, display settings, etc... Whenever I get a new piece of tech candy, I ALWAYS d/load the PDF manuals and store them on the HD in case the paper manuals get lost, torn up, thrown away, etc... Go here and d/load the English stuff and check 'em out. One of them is the expanded manual.
http://www.eclipse-web.com/us/download/manual/index.html
CHECK THIS OUT!!! I was looking for the manual stuff and wandered across this webpage...
http://www.e-iserv.jp/portal/dispTopMenu.do?lang=na
Supposedly, it allows you to d/load wallpapers, moving graphics, AND a tool to make your own stuff!!! Trick is, I don't see anything DIRECTLY related to the CD5030, but if the d/loaded stuff doesn't work, perhaps the tool does! You'll need a USB flash drive to u/load it to the radio memory, but the instructions to do this is there. Sweeeettt....
