Ebay T4 manifold..will i need a turbo spacer?
suprafanatic
1,607
Greenwood, IN
Has anyone used the T4 manifold off ebay? i bought one from SSAutoChrome. Then i was told that i will need to also buy a turbo spacer to lift the turbo up more. because the compressor housing will hit the runners of the manifold. Has anyone had any experience with this issue? As for the turbo, i'll be using the new 67mm Billet turbo.
buckshotglass
I love all your sounds.
Only a dark one..
When I find my camera, I can get a better one if you want.
suprafanatic
1,607
Greenwood, IN
wow that looks nice and shiney.. haha.. but ya if you could get a picture of it with better lighting that would be great.. i just want to see what im going to be faced with before i start my turbo swap. thanks!
Halsupramk3
444
Mississippi
i had a custom spacer made. it is taller on the strut side than the exhaust manifold side by about 1/2 inch. it is also about 3/8 inch taller on the front than the rear end. it is about 2 inches tall in the middle axis left to right. this moved the compressor housing away from the strut tower so it did not hit it. there is about a 1+ inch space there now. i could put a T 90 or some big shit in there now. this is with the old ss chrome manifold.
it is also angled about 3 degrees i think so that the intake points towards the headlight and the rear dp side is closer to the engine. this allows the dp to go straight down the hole behind the turbo and not hit the wall.
Captain
80
NM
I am curious to see if anybody has run a turbo on one of these manifolds with out a spacer.
I'm running a GT40 and it wont even come close to fitting without a big spacer. I think I needed a bit more than 2".
Intercooler piping kinda depends on where your compressor outlet ends up sitting. I can post pics if you would like.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i have one 1/2in adapter on my manifold with the hy35 holet,would have touched without it
dbsupra90
toonar
indiucky
i dont know why you guys are having issues. i have the s-cover on mine with a 5/8" spacer. a 3/4" should be more than enough on an S-cover. an H cover or GT cover is a different story.
dbsupra90
toonar
indiucky
suprafanatic;1395928 said:
looks like the same manifold i got.. what turbo is that though?
if you got the older style manifold it looks like that. if you got a newer style one the flange is twisted slightly. the turbo is the same as i got for you.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
How would that compare to a MP T-70? i just ordered 2 flanges and when i get them im going to stack them to see how it fits, if i need any more space and ill weld in some 1/4 inch plate to make a riser.
