Ebay ClusterGauges
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
Alright so i got my gauges off ebay some of those indiglow ones that look sweet. My question is do i keep the main wiring in for my dash now? it didnt come with any directions anyone have a step by step on how to do this? because if i unplug my wires to the dash i wont be able to see the needle right?
Mr.SelfDestruct
I build planes... yeah...
May 27, 2005
608
everett, WA
no, I mean, take the wire for the faces, and run it to the headlight switch, or a toggle that leads to the + terminal on the batt. then just run everything else to where its supposed to go, and you'll still see the needle. I dont have any pics, sorry.
White VIIM
....new?
Jan 23, 2006
13
NJ
hey guys, i think i have pics of these particular gauges, are these them?
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
alright so i got them without too much trouble... i have a couple questions now.... when i put the oil gauge needle back on it was resting at 0 but now that i have put it in it will set at like 20 without the car on ... after i turn the car on and turn it off all the other needles will drop to the starting spot... the oil needle is working it will rise up when the car is on... should i be worried?
alright my second problem is there is a on off switch for the gauges how can i bypass them so they will turn on if there is power to them? i have them hooked up to my dash lights right now so there is only power when i turn the head lights on? i tried just using a jumper but that didnt work
Suprastic
727
Manitoba
send your puwer wire to a 12V accessory (ie: cig lighter) and your black wire to a ground (ie: dash frame). Hope this helps. GL
87centertips
107
edmonton alberta
i have a couple questions one dose anyone know were to get one kilomiters not miles i tried some stores here but none of them sell parts for the mkIII or the MKII no that i think about it for none of the supras and what if ur cig lighter dosn't work were else can u put it on the dash
