About 2" longer than the stock lower intake manifold runners. He cut the flange off that normally fits to the stock upper and welded/blended the extensions between the plenum and runners.
He did do the EGR tube. The problem with running it inside or under is the way the stock EGR valve to tube fitting sits. It's higher than the runners and very close to the #6 runner preventing a curve down. It was just too hard to do and still employ the KISS principle. The tube is going to be ceramic coated black with a fire sleeve around it...it easily clears the fuel rail as well.
