weak....... me and Rumptis can take two motors out, put one back in in less than 5 hours (I'm pretty sure thats what it was) Pull motor/trans together, take the harness out of the dash, (MUCH easier than pulling the intake the old fashioned way), disconnect all the hoses/wires and such, take out the rad, jack the back of the car up and start pumping the cherry picker. We pulled a 6m in less than 45 mins, start to finish, I think the hardest part was maybe the motor mounts, and even those are easy, well, maybe the trans mount was the hardest, I dunno. Anyway, I'll pull out everytime... 26 nuts, that even sounds like a PITA.*edit- lol, oh, the oil pan bolts..... lol just looked at the TSRM* Honestly though, how hard is it to seperate and reconnect the trans on the ground? we're talking 20 mins, MAX of work, and change the rear seal, it's only like $10-15 You'll be glad you did. oil pump.... thats crapp, have yet to have one go out on me and my 5/6ms were probably pushing 150+K. hardest thing on the 7m's I would say would be the fuel line...
and those who take the intake off to get the harness out, seriously try taking it out of the firewall instead. I did it once, and I will do it from now on. it seriously cuts the time in half, if not more. all you'll need is a long pair of needle nosed pliers, maybe a coat hanger would work, I dunno, to pull it through the firewall, and you're done.
As far as sealer, I used "the right stuff" no word yet on how that's gonna work for me, still need a couple of wires connected and I'll be ready to go. :icon_bigg Hope I helped out a little, I know I like to talk. :icon_conf
