This is the wiring for an early '89 Turbo Supra 5-speed. The plugs will actually fit a '87 and '88 but the wires were changed and removed from some plugs so please note the differences.
A lot of people think there are 87-88, 89-92 wiring harnesses, but there are more combos. Hope this helps.
B1 Plug
1. Heater Water VSV---------------------------- Black \ Yellow
2. L3 to ECU used for -TEMS------------------------------------ Red / White
3. L2to ECU used for TEMS------------------------------------- RED
4. L1 TO ECU used for TEMS------------------------------------- BLACK
5. Check Connector for Fuel p--------------------------- Black \ Red
6. Circuit opening relay coil---------------------------------- GREEN
7. A/T circuit for coil opening relay----------------------Medium / Black Blue
8. Fuel Pump Relay on ECU----------------------------- YELLOW
9. Switched 12v For EFI From Fuse box- also +B check connector--------- Black \ Red Medium
10. A/C water temp switch ---------------------- Green \ Red
11. Goes to Start Solenoid-------------------------- HUGE Black \ Blue
12. A/C Compressor Magnate switch TO ECU------------------ Blue \ Red
13. TEMS Check Singal------------------------------------ Purple
14. NSW for clutch TO ECU -----------------------Black \ Yellow
15. Ignition switch to ECU-------------------------- Gray
16. +12v for igniter and fuel injectors etc, also resistor in engine bay --------------BIG Black \ Orange
17. Theft deterrent horn plug on harness -----------Yellow \ Blue
18. From headlight relay for Idle up, goes to ECU ---- ----------–Red \ Yellow
M1 Plug
1. Signal backup light switch --------------------------------------------- Red \ Black
2. Positive for backup light switch Plus for Heater water valve VSV --------------- YELLOW
3. Speedometer signal from ECU to combination meter ------------------------- PINK
4. Ignition signal to tech, from check connector to igniter------------------------ BLACK
5. Turbo indicator light signal for combination meter, also A1 plug----------------- Red \Green
6. ECU ground and Water temp gauge mass signal ------------------------ ---- BROWN
7. From pressure switch for oil gauge, also from ECU---------------------------- Yellow \ Black
8. W signal for warning light on dash ---------------------------------------- Grey \ Green
9. water temp sensor for combo meter Yellow –------------------------------- GREEN
10. From defogger relay also goes to plug A1 - ----------------------------- PURPLE
B3 Plug
1. Rear ABS Sensor wire-----------------------------------------Black
2.Rear ABS sensor wire---------------------------------Red/ Black
3. Rear ABS sensor wire-----------------------------------------Yellow
4. Progressive Power Steering Solenoid--------------------White / Red
5. Progressive Power Steering Solenoid---------------------White / Green
B1 Plug
M1 Plug
B3 Plug
