E-Manage? and HKS Head gasket?
TheNewRed
572
WA
Hey guys i have put the supra down for this winter, and i am going to be getting a lot of parts before december, and my questions are....
1.Would you all recomend the Greddy E-Manage, why or why not?
and
2. Would you all recomend either the Hks 1.2mm bead type, or the Titan 1.4mm metal headgasket?:naughty:
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
and
I dont think the greddy E-Manage has base maps for our supra. I remember someone on the boards saying this.
About your HG, get the size according to how much material you had shaved off the block. Then, get the correct size to compensate.
Someone will clarify and better word what i'm trying to say.
-Steve
Vsalvatierra86
Norwalk, CA
E-manage SUCKS!! from my experience...had a couple blown hg due to that..
and
bowsercake
828
Irvine, Ca
It's not the E-manage that sucks, it's your tuning that sucks.
There is a lot of misinformation about the Emanage on the forums. There are two different versions, the Emanage Blue (older) and the Emanage Ultimate (newer). The Blue definitely works on the 7M and it can adjust timing with a cheap, homemade circuit. The Ultimate could work on the 7M using the same settings as the Blue but it taps into 5x more ECU lines than does the Blue so it might be difficult to do as the 7M is not a listed application (that doesn't mean that it will not work though).
Blue:
-16x16 air map based on TPS and RPM
-Injector Duty cycle adjustment
-Add 2 extra injectors
-Connect wideband and log
-Can hook up to the Profec E-01
Here is how easy it is to set up the Blue:
http://www.mohdparts.com/emanage/install/supra_mk3/ignition_emanage2.jpg
Ultimate:
-Same as above
-Allows for removal of the AFM (similar to the Maft-pro speed density)
-Much more precise tuning allowed
If you have the Emanage already go for it. If you really want to eliminate the AFM than you should look into the MAFT-Pro. However, for the money the Emanage Blue is very capable and people have made a lot of power on it. If you are looking to make 500+ hp than you should invest in a standalone.
87trbo
houston,texas
well the titan gasket is good from wat i red on horsepowerfreaks.com review of the gasket i just oredered 1 and i dont have any regrets so check it out yo
TheNewRed
572
WA
wow guys , thanks i guess i will be going with the Titan, it sounds more reliable, and i am leaning more and more towards the emange. But one more question, cant the emanage control the fuel side of town too?:icon_bigg
bowsercake
828
Irvine, Ca
Emanage can control the KV signal which will allow you to change tune your A/F ratio, it can change injector duty cycle, it allows you to add extra injectors, and some other stuff.
However, unless you are getting a good deal on the Emanage you should look into getting a MAFT-Pro. A lot of people are using this piggy-back and it works well. It also allows you to remove the AFM with more add-ons if you wont. The Emanage Blue will not let you remove the AFM.
TheNewRed
572
WA
But isnt the MAF-T like $800?
