E - Brake light stuck in the on position
SupraStoked
yea it was gradually getting lower on fluid, very slowly though. the light went off after I filled it up more but there has to be a leak sonewhere. I just did my brakes about a month and a half ago. I get this weird sound oon my rear passenger side when I brake and start to almost come to a sound. it sounds like the quaking of a duck and as my speed decreases, the period of time in between each 'quack' increases.
Sent from my LS670 using Tapatalk 2
Jtsan
Brockton MA
I would check for rotted brake lines. Maybe even get someone to press the brake while you look under there.
When you say "just did brakes" what did you exactly do?? Pad slap? Cut rotors or replace them?? Did you lube your slides??? How did the hardware on your caliper bracket look?? There could be many reasons why your brakes are making noise.
