Push;1305456 said:
Your motor seriously has issues... My stock 5mge automatic made more power!!!
Hey all,
Y'all do realize that above and beyond the obvious tons of miles it's got on it he could have a "midas special" pea-shooter exhaust with a "super-mega quiet" suffocating muffler, or waaaay too big an exhaust for N/A's with a monster fart-can and too little back-pressure, retarded timing, etc, plus no two dyno's read the same either, even if they're both the same brand.
Racing Solutions Inc's DynoJet (when it was still in Houston in 2007) said my 98TT 6-Speed Supra with a slipping TRD Single-disc clutch and stock flywheel made 392whp with the boost controller off and 436rwhp with the boost controller on right before the clutch let go unexpectedly at 16.5psi of boost, then Hennessey Performance's DynoJet said it did 401whp on 16psi in 2008 and 428whp on 24psi of boost in 2009 with a RPS twin-disc clutch and RPS lightweight flywheel in it for both times it was on the Hennessey DynoJet... Same GReddy 3-Row Intercooler, same exact full 3" exhaust, etc...
A previous owner of my 98TT also has dyno sheets showing in excess of 480whp from the car on some dyno in Dallas with almost identical mods as what I have on it now, same intercooler and exhaust, etc, although he had that TRD clutch in it at the time when the TRD clutch was still new and holding up properly.
Hennessey's DynoJet also showed almost 100whp lower recently for a buddy's single'd MkIV than Boost Logic's dyno numbers in austin just weeks earlier when they did the single conversion, so which dyno is "wrong"???
Basically neither is "wrong", just different conditions, adjustments, etc.
So unless you dyno 2 cars on the same dyno you can't really compare notes very well apparently and he shouldn't feel bad... He put down better whp numbers than my former 96 Camry has as stated stock crank hp/tq numbers.
I didn't really notice a mods list in his thread so if I missed it, sorry...
I suspect that he needs to jumper out his T1(TE1) and E1 to put it in diagnostic mode, start the car and check the timing with it in diagnostic mode (should be 10 degrees in diag mode), then get a K&N FIPK Intake and a complete stock 7M-GTE cat-back with a test pipe, set the timing at about 15 degrees instead of 10, and try it again.
The GTE cat-back on a GE seems to be a near perfect balance of flow and back-pressure to keep the N/A's valves happy and a test pipe works really well on that cat-back if you can get away with it on emissions testing.
The stock auto is a bit of a power kill compared to the W58/R154 but not by that much...
My old 87 N/A auto with the sport package and 170k miles on it would climb strong, smooth, and easy from about 70mph on up well into triple-digits and peg the 150mph speedo pretty effortlessly once I did the above listed mods years ago before Katrina turned it into a submarine...
The only drag pass I ever made in it was mid 16's with a full tank of gas, the a/c on, and a 24x8x2 Mackie mixer in the hatch along with all its' interconnect cable snakes and my work tools, and it was totally 100% stock with the full original GE intake and exhaust and stock sawblade wheels at the time... I have no idea what it would dyno. Never got around to it.
As long as you don't run that N/A low on oil or coolant or let it run hot it'll start every time and get you where you need to go, regardless of what the dyno says...
hottscennessey;1305473 said:
I think your VTEC is broken.
C'mon dude, get it right... It's a Toyota... His VVTi is broken!
