Dyno
OneJoeZee
Retired Post Whore
aboard the Argama
Markiii;895691 said:
which diff is this with? I've got a 1G with a 7MGTE diff so is 4th still 1:1 with this set up?
I'm planning a dyno soon so this will be useful to know
Cheers
The differential doesn't change your transmission gear.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
suprahero;895238 said:
I would hate to get kicked out, but I'd also rather not lie to them if I've did something wrong. I've always heard you'd dyno more in fourth gear. If this isn't true then I got some splainin to do to Duane and Miguel.
It won't matter once I get my 1.5jz done though. Ill have to be in the 2jz section anyways.
Chris, would I dyno more or less in third gear? Thanks
I forgot all about this thread, you should be a little lower, but like you said, it's not going to matter for you soon anyways ;).
