I have seen a couple of MKIV dynos on SF where the filter hurt power by a lot (massive turbos). Even though it was a massive 5 inch pipe going to the fender, they gained a butt load by removing the intake. I really don't have time to search for one of those threads right now...
I agree that I should always run a filter on the street. For the dyno, I want to know if that number is all it would put out. I increased the timing all the way to the point of no gain, and back down a degree. I'm running aggressive on 50/50, but I am not making the power a lot of other guys are making with a 74mm.
I know the block I was on was old, but 27PSI on a 74mm turbo with maxed timing on 93 and 50/50 just makes me feel something is wrong based on the power. If the filter is as much of a potential restriction, I'd like to try another brand like AEM.
Only problem, the manifold and intercooler piping are restricting my options to a shortie style 4 inch inlet, and I can't seem to find one. Another concern, once I do find one that fits perfect, it may not have enough surface area or flow as much as the one I am removing.
Shaeff, I hear ya. I just want to make as much power as my engine is going to make. On the dyno, on the street, wherever.
I'm going to look around, and I'm open to ideas. Thanks.
supraman7mgte;1682970 said:
dam impressive numbers with a K&N.
i would replace that with a dry element,ive heard nothing but bad about a oil impregnated filter and our type of afm
Thanks.
I washed all the oil off my K&N anyway, AFM or not. A new dry element is in my future
