Zazzn said:awesome xman! I bearly pulled my friends 18 PSI gt42 7m powered supra in my 1jz @ 20 psi with the k26 twins.
That thing is gonna be a beast... btw, looks like you are going to have to turn up that rev limit... Under 2k of power is a lil annoying!! I'm sure with a little anti lag settings on the AEM and some fooling aroudn you can pull 200-300 RPM back of spool.
can't wait for the final result.
supra87t/t4 said:Obviously the big backfire is well beyond the normal stress on the manifold, but speaking from my own experience a design that has those corners bent into the sheet is much stronger than welding two flat sheets at 90*. I mentioned it in one of your other threads and I'm not too suprised to hear it ended up cracking. I had the same problem with some intercooler endtanks I made that way, the next set I bent those two long corners and didn't have any more problems. It's a bit more work, but see if you can find someone to bend that up for your next one, plus it's that much less that you have to weld.
Glen
dbsupra90 said:i was just trying to make a point that it did fine prior to the stick of tnt inside it. it held up fine multiple beatings of 25-30psi w/ the sp67 on it.
Glen
blackout_89t said:I disagree, a proper penetration welded joint will be far stronger than a folded edge, especially in such thin gauge metal. Unless of course you try to make it look pretty afterwards and grind the welds down, then it will crack, especially in an area that can only be welded from the outside.
[/hijack]
supra87t/t4 said:How do you think a formed (bent) corner is going to fail? There is no welding to weaken the base metal and nowhere for a crack to start, the bend will leave some radius in the corner and that reduces the stress compared to a "sharp" corner made by two plates. The way alot of these manifolds are made you end up welding the thinner sheet to a thicker plate at the joint you are showing, in that case you don't have alot of choice, I was referring more to the other joint where the two thin plates join, which I can't really see in your pics.
Give me some credit, I basically predicted the failure and suggested a possible improvement from my own experience. Sean's cracking may have never hapened without the backfire and it may be fixed with different material or welding. A properly welded corner in the right material and thickness will no doubt do the job, but there's no way it's stronger than a formed corner in the same material.
