Well as some of you may remember i when i went to the dyno last time my boost was going haywire and only managed about 220HP at about 5~6lbs of boost. I eventually found the tubes going to the greddy control valve were switched and thats when the fun really started. I went back today finally to find good and bad news.
Results: 257.1RWTQ @4700~4800RPM and 259.51RWHP @5500RPM or so. Believe it or not those numbers are running on only about 7.7PSI on stock ct-26.
Bad part: i'm only getting 7.7 psi at my max power, i hit about 10.5psi to start but simply start to bleed slowly after. After 5K it bleeds at a pretty fast rate only holding about 5 PSI by 6K.
Solution: new turbo, ie 57 trim... hurry up with that 57GT wheel MDC :1zhelp:
conditions: 91 degrees, 36% humidity, 29.61 in-Hg, STD 1.04
Edit: Since some of you got wierded out it seemed w/A/F heres just a couple of today's runs/ Red and Orange are the last run.
