dyno day ct-26!!!
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I don't understand. i have mods that surpass yours (minus your turbo) and only made 260RWHP and 260RWTQ. Now i have a boost leak in my EGR believe it or not which drops it off to around 7.7 PSI at max power but still.....
tissimo
Stock is boring :(
Melbourne, FL
seems slow for 350whp.. too much heat for the intercooler maybe cutting down on power on the top end?
fwiw i made 289 and went 102
MRSUPRA
838
Maryland
Nice numbers.. I didn't think a stock CT-26 could make 350rwhp.
I bet cooler temperatures at the track would give you a better mph.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
quake said:
just put the sup on the dyno mods include .20 overbore wiseco all arp cometic gasket 550cc injectors vpc no afc yet full turbo back 3" precision front mount blitz blow off greddy ebc air fuel went sub 10s after 5600rpm so more tuning needed before that rock steady 11:1 end result 325whp and 394tq at the wheels! now we put the 67 back on :icon_bigg peak boost 18psi holding 15psi
Where is the dyno sheet?
shaeff
Kurt is FTMFW x2!!!!
11
Around
and a pic of the engine bay. i'm having a difficult time believing that a STOCK non-upgraded CT-26 made that much power...
-shaeff
Dec 3, 2003
6,653
Canada
quake said:
update: dynoed on last friday and made 407rwtq and 350rwhp will post dyno sheet tomorrow. Also ran 13.7 at 105mph will see about posting vid this was on 18" rims. selling this turbo now as my new one is on the way make an offer
105 MPH doesn't equal to a 407 RWHP though..I assume the boost was lower when you ran it Quake?
-shaeff
You can't tell what has been done to the inner by looking at the outside of turbo ;) BUT don't forget the compression he is running.
Duane
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Duane
It was 407 rwtq and 350 rwhp
Dec 3, 2003
6,653
Canada
2543arvin said:
You're still right, something must be wrong....
I am actually on the phone with him now and he had mentioned that the power drops off at higher RPM.. he will post a dyno sheet later. It may explain things.
Duane
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i think tissimo is right on this one. i think its just getting WAY too hot up top and its hurting it BAD
on 12 psi on my 1J with just a 3" exhaust my car went 13.7 @102. some thing definitely aint right!!!
shaeff
11
Around
duane- true, and i must have missed the CR part. ;)
-shaeff
tissimo
Stock is boring :(
Melbourne, FL
Duane
it doesn't matter if power drops off, it still isn't putting down the 350whp going 105 mph.. what correction #s were on the dyno..
suprarich
Guest
Nov 9, 2005
2,187
ohio
My stock ct did 359 rwhp thru an auto It can be done.
