I believe i met you at drag-way 42 last weekend. You got a nice setup on your car. Can't wait to see some more video's.
2JZ_MA70;1137478 said:OK final number is 602whp/550wtq !!! The impresive thing is the power under the curve... You can make peak numbers all day long and run slow on the track and the street that turbo is outstanding steet turbo for this engine
If it wanst for Tim at Switzer Performance (home of the world fastest Porsche 997 turbo) much of this would have not been posible. He helped me with the build and tuned the car. Man I still cant belive it.... I cant wait to drive it.!!!
Mods are: 3" turbo back no cat, Tub manifold with 60mm tial gate, 2.5" int tubing, 24x12x4 Int, 1600cc, Twin Walbros, AEM EMS and C2DI... that is about it. Stock motor. All bolt-ons.
But yeah the stock cams are definetly a limitation at this point. I can get them reclocked for top end...but its somewhat pointless.
We are building it with response and good street use in mind.
I posted some pictures on page 3-4
New vids of the track and one dyno run...
10secdream;1368290 said:Awesome setup and one amazing tune. Great job.
gonzy tunning;1503541 said:nice set up bro...post some real vids man
2JZ_MA70;1365020 said:The car has been down for some time now.... Driveline problems... Trans cant hold the power even with the Marlin Crawler upgrades. Destroyed 3 of their washers. They are not breaking but are wearing out and damaging first gear. I have spent $2k on fixing transmissions in the last 3 mounts and the last one lasted 2 hours after I put the M/T drag radials.... Im tired of this and I dont want to go auto. I think it would kill the fun in the car. and I like to get over 150mph once in a while... so I have been working on a T56 swap here is the tread...
http://www.supramania.com/forums/showthread.php?t=100988
So far Quick Time Inc. will try to make a bellhousing ~$600 (They are making two so far one for me one for my buddy), will be getting a clutch that I will be trying (Quarter Master 7.25" Twin Rally, or Triple Optimum-V with Button flywheel and auto Flex Plate for the crown gear)~$600. The drive shaft ~$400. I will need master and slave cyl set up but that is easy also ~$400... The trans will be T-56 Magnum (TR-6060) ACR Viper, ZR1 Vette, CTS-V, GTO.... Aston Martin Vanquish and DB7.... Its been used is some nice rides.... =) and that is $2800.
Its not cheap but by the time I offset the cost by selling parts I already have it would not be out of reach. It beats $5600 for a new V160 + Clutch, drive shaft, mount....
