I am working on installing brake ducts and just want to make sure before i cut that what i am doing is ok. i need the shield to be removable so im simply going to cut out the area between two of the bolts so that the shield isnt a full ring. the issue is this cut exposes the hub directly to the back of the hub flange and potentially brake dust and heat. just wanting some opinions. here is a picture showing where i will be cutting it.
