Dual walbros, going lean at 1/2 tank...
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
Hey guys,
I was wondering if other people have a solution to my problem other then sumping the gas tank..... Basically, I need to have over 1/2 tank at all times or I go lean because the injectors don't get fuel.
blazerkd
dayton,oh
If you've got the funds.....which you may because it seems you're making good power:
-6 feed
-8 return
-20 gal fuel safe
-aeromotive a1000 pump
This would put an end to all fuel system issues; but if you don't want to do all this, I know that you can fabricate a better sump while still retaining the factory gas tank and go to inline fuel pumps......such as what Duane is running on his 7m car.
Zazzn
7
Toronto/SF Bay area
Nick is that you? Nholden dayton ohio?
Nick it's eric from toronto...
And yes, I really don't want to sump i guess it's just a flaw of the tank then that it can't flow this much?
Zazzn
7
Toronto/SF Bay area
Figgie, why's that? yeah there is no charcol can it was huge, no space for it with the 4" i have a 1jz charcoal can that I could hook up... Why? I have a VENTED gas cap btw since I blocked the can line. since it's no longer used with my hanger setup.
The tank needs to be under positive pressure (2 psi to be exact). It prevents the pump(s) from cavitating. The evap system (charcoal canister) provides that positive pressure and the correct tank relief pressure. Using a vented gas cap defeats all that ;)
tekdeus;1276724 said:
I thought Zazzn's problem was his 647rwhp pulling so hard it's pushing his gas to the back of the tank and starving the pumps?
Huh? If the pump pick-ups are covered, why would that be an issue? I can see it at really low tank level, but that would cause the motor to cut from lack of fuel.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Leave the OEM Evap setup alone it is fine & I also use the JZA70 carbon canister its mounted on the bracket to the brake booster 10 mm bolt & uses the OEM evap line.
Fuel return I use the oem fuel feed + the oem fuel return line I use a Y to run them in parallel to the fuel regulator.
Fuel feed is AN-10 with single aeromotive pump it will do for now until a fuel cell will be fitted.
Zazzn
7
Toronto/SF Bay area
I can't remember what I did to the evap line, but I'm sure I cut it way down near the frame because my new hanger didn't have a Evap line. This could be a problem (easy to fix run a new line) but the hanger for the pump could be a prob for getting an evap line in there.
Question, I never had this problem with 1 pump with this setup previously? The pumps should be in the stock pickup area...
You see when i get under 1/2 tank I know the pumps are staving because I'm getting no accel, some times when i get in to boost, and espeically if the engine line comes on (tells me it's lean for my AEM)
If I get a non Vented cap I basically need a charcoal can which provides 2 PSI of backpressure in the tank? I know my aristo sounds like opening a pop bottle when you go to fill it up.
2 pumps may be enough to create a vacuum in the tank and this will starve the engine.
Next time it's down to half a tank try taking the cap off and driving it to see if it still leans out.
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
nobody kill me but a option is to put a 2psi residual valve in the vent line from the tank. willwood makes these for disc brake setups but they should work for the fuel vent to. (i know everyone here wants the CC on but for my road race car i dont want nor need that big thing in the engine bay
