Dual stock intercoolers
Status
Not open for further replies.
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
Anyone ever do a dual intercooler setup using PVC intercooler piping? I saw it on www.jblmk3.com but nowhere else. According to jeff's website, the stock IC has almost no pressure drop from inlet to outlet.....which meens that 2 IC's would be twice the flow...right?
hellraiser456
130
canada
to me you are still better off with an aftermarket intercooler. the toyota intercoolers are easy to heak soak at anything over stock boost. i don't think having two will make a huge difference.
loki2043
645
Portland, OR
double heat soak? lol
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
aftermarket replacements are cheap enough to get a hold of. if the only other options were 700+ i could see doing this.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
s383mmber1 said:
I would love to see how this is a fact? Because here, your simply wrong.
nice.
i'd like to see the dual stock IC setup done, but if it was my own choice, i'd just get myself an ebay IC, as maybe i will one day.
s383mmber1
3,614
Somers New York
John specified that he thought it was not worth the effort in his opinion in his website, at the bottom.
So take that as you please. Although the stock intercooler is very efficiant, and many do not find it to be a restriction untill 350+ horses. The real restriction is in the piping :)
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
ill sell ya my HKS drop in if ya want lol. i noticed a big difference over stock with just teh HKS drop in. at night when it cools of to around 50-60 in the summer it would run awesome with the stocker but then during the day when ti was 80-90 i could feel the difference big time. with the HKS drop in it ran like it did at night during the day and better during the night. im only running 10psi stock turbo.
Sock IC FTMFL.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The stock IC's flow well for what they are. Two of them will not improve flow...this is where the piping is the factor like S383 said. Two would improve air charge cooling efficiency, but not by a factor of 2...you would hit diminishing returns pretty quick.
jdub
Feb 10, 2006
10,730
Valley of the Sun
lintlars said:
please dont give out false info theres enough floating around and yes I have tested it
http://www.supramania.com/forums/showthread.php?t=10779
Chill out dude...I said they flow well for what they are (size core and inlet/outlet dia). Of course a Spearco is going to flow better...larger core and larger inlet/outlet.
I'm not giving out false info...I was addressing the cooling efficiency of dual stock IC's and how 2 of them will not increase flow. You know, what this thread is about ;)
Maybe you need to work on reading comprehension?
s383mmber1
3,614
Somers New York
Very true, we never said that the stock was THE BEST INTERCOOLER IN THE WORLD!
But, for what it is, its very efficiant, and supply's many people in the 400 HP range.
suprarich
Guest
Nov 9, 2005
2,187
ohio
You could split your piping into two paths just off the turbo. Run one path through one intercooler, and the second path through the second intercooler. After the intercoolers, you could bring both pipes back together into one. This would split the flow and the work in half as each stock intercooler would get half the air.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ahhh...working in parallel vs series. A little complex on the piping side, but should increase flow.
CampbellsChunkySoupra
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
if u split the flow of the air into two different setups wouldnt they have to be 100% exact angles and lengths to get the same flow back out of the other side? id assume u'd need some sort of "Y style exhaust" design. ud need the piping to be very similar so that the pressure stays the same all the way through? or am i wrong.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yeah, you'd have to put some thought into the piping design. Like Joe said...too complicated to be worthwhile. A Spearco (or knock off) would be a lot easier and give you the flow you need.
Even though impractical, it is kinda neat thinking about how it could be done ;)
tte
Breaking In - in progress
Northern California
Yes, Keep it simple...
Too many piping, clamps, hoses....more risk of a leak.
A good aftermarket one will serve your needs well.
Cheers,
Roy
Status
