Dual Piston Previa Caliper
Status
Not open for further replies.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Turbo. Targa. Life. said:
lol @ tubbie
2.37X1=2.37
1.75x2=3.5
:umno:
The area of a circle is Pi x radius squared.
The 2.37" caliper has an area of 4.40"
The 1.75" caliper has an area of 2.40 X 2 = 4.80"
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
jdub said:
:umno:
Still sold, I think the dual pots will also help me stop cracking pads when I mash the brakes.
On my stock calipers I always have a large crack down the center of the pads right where the center of the pot is. Ive tried 3 brands of pads so far that have done the same.
frank
BC
Stock: 4.11 sq/inch
Previa:4.81 sq/inch
Using measurements given above. So approx. 17% :nono: (wrong. 9%):icon_conf more clamping power.
However, as pointed out above, if you can lock them with the stock calipers, you won't gain anything. (If your supra has ABS, as mine does, they don't normally lock anyway.) There may be some advantage heat build-up wise, as there may be more fluid in the caliper to absorb heat. I'm too tired to properly think through the ramifications at the moment. Someone else's turn.
Edit: oops, someone beat me to it. That's what happens when you're tired and type slow...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Frank - check your math ;)
It's actually an 9% increase in area with the Previa caliper. Really not worth it IMO unless you have to replace your calipers anyway. However, the dual caliper should help spread the clamping force better across the pad.
drjonez
the motor city
www.4cefed.com
jdub said:
:umno:
bingo. math/geometry is pretty tough....:aigo:
as jdub said, it's probably not worth running out and buying them right now....but if your calipers are ailing, wouldn't hurt to step up to 'em.
frank
BC
You are absolutely correct. That's what happens when you use 4.11 as the basis of your calculations instead of 4.41. :icon_conf Dyslexia anyone?
Status
