7mBoost - So what numbers are they? Exactly the same numbers I pulled out of my ass. Lets resolve this so read down....
I'm not here to bash on JDUB or anyone else and I don't believe I've done so. Stop acting as if I have. I've been more then amicable to everyone! JDUB got me a little razzed when he was calling my fix a “ghetto”. While IMO his suggestion of fixing the ABS would mask the problem not resolve the problem, which I believe was the ghetto fix.
THANK YOU JDUB I appreciate the insightful input, sorry if you feel offended. I did NOT START THIS THREAD TO BASH ANYONE especially you.
I want to find a solution to the problem that has been created by upgrading my front breaks only. This is one of them hidden "bugs" that you find with may upgrades which people do not talk about very often.
I just got off the phone with Steve Jarvis form supraforums, we talked for about 4 hours! Initially I called him for his expertise on wheel fitment on the mk4 for road racing and we some how got talking about breaks.
He informed me that he did a BBK on his MK4 on the front only and ended up with worse stopping distances and challenged me to try a test with my new BBK vs a stock system to do a full stop form 60MPH and assured me the stock system would stop sooner. He then upgraded to the Rotorex 14" all around and could not believe how much difference it made.
He completely agrees with me that just upgrading the fronts will cause you problems because of the breaking bias. Also a prop valve will not work in my case as IJ has said. He also agrees that ABS would just band aid the situation.
If you don't know who Steve is check this out
http://www.geocities.com/steve_jarvis_me/
He's an Instructor at VIR and he's done plenty to his supra to make it go fast around the track.
So lets end this squabbling about numbers out of ass controversy. Can someone who measure the stock calipers break piston diameter since I'm not in the same city as my mk3.
I need the diameter of the mk3 front piston, and the same for the rear caliper piston.
I will then be able to calculate the change that has occurred and we can see just how much this has changed the dynamics of the car.
AGAIN i'm not bashing anything or anyone here just want my upgrade to actually perform like an upgrade.
