Jdub, you need to calm down, you need to step back. The anger and tone of your responses do not help anyone. I appreciate your feedback but there is no need to make anyone feel stupid, dumb for lack of knowledge on a particular subject.
I appreciate all the info that has been shared here. Adam, 2jz_ma70 and enraged thanks for seeing my side of view.
While I understand everything that JDub is saying, I don't think he understands my problem clearly. Yes the ABS would fix my solution but not the way I would like. It would entail me to mash the breaks to the ground to achieve 4 wheels to lock up however; the ABS would trigger fixing the issue.
But this is not my goal, I would love to hit the max break threshold on all for corners without triggering ABS, which is impossible now. Quite frankly the car worked very well without ABS on the stock system and now it is actually quite scary and unpredictable because of how quickly the front breaks grab.
I don’t know if you have these brakes Jdub, but if you don’t then how can you argue my estimations on how the breaks feel. When I say 95/5% 6 these numbers are partly out of my ass since they are form the seat of my ass estimations.
I have them on my car and I know how the car felt previous to the breaks.
-Doward I’m not saying there is anything wrong with the breaks, I’m just simply saying I need a solution for this which does not include working around the issue using ABS. The BBK is doing everything as advertised, and I knew this would probably be a problem that I would have to solve. I will eventually fix the abs, but as I said I don’t like the ABS on the mk3 because if you hit a bump in the road while trying to break lightly, it triggers the ABS as the wheel locks for a split second, while all my gen 2 abs systems do not do this. (mk4 supra and aristo)
I'm trying to achieve max break threshold on all 4 corners but I cannot achieve this ANYLONGER because I have too much stopping power in the front. If depress the pedal 1/3 of the way down I am at max threshold on the front and it’s borderline locking up however, the rears are barely doing anything. The ONLY way I can achieve max threshold would be to lock the fronts triggering the ABS and then keep pressing harder on the brake pedal so that the rears get more pressure. That is unless I don't understand the ABS JDUB. In which case does the ABS divert more pressure to the rears when the fronts lock?
