Its getting worse and its definetly time I do something about it, The rear end is really clunky now, I rarely beat on the car but I think its just a wear and tear thing from the rough roads here. Im taking the car off the road for winter soon so il have no problem tearing it apart, I have a press and torches and all kinds of tools, bushings should be a problem. So far heres the list of what I know I need to order:
Driveshaft Center support bearing
No.2 lower arm "ball bushings"
Energy Suspension rear bushing kit
Marlin Crawler shifter bushings, ordering stuff for my truck from them aswell.
Struts
My limited slip has a bit of clatter so il have to change the fluid and see if that helps. The w58 has a whine downshifting in 2nd and faintly in 3rd, again fluid needs doing but I need more input on this issue, probably not just the fluid.
Anything else I should deal with back there?
Struts
