Driveshaft critical speeds.
Doward
4,245
Alachua, FL
I'm doing some quick and dirty calcs, and I think a 9000rpm critical speed will be good for me for the following conditions -
7200 rpm redline
25.66" tire
3.91 rear gear
r154 tranny
http://www.markwilliams.com/driveshafttech.aspx
Looks like a 3.5" mild steel will be the way to go for me (isn't stock DS length like 45 inches? Dammit, I have to measure mine - '88 auto converting to an r154)
Will possible go to 3.73s down the line (depends on how my power band feels)
Thoughts?
Doward
4,245
Alachua, FL
IJ. said:
Dow: At 7200 your shaft is turning 9600 in 5th with a R154...
I'd want at least a 1000 rpm safety margin.
You're right, I miscalculated that. :(
So far, the problem has been nobody's got an r154 flange that will accept a 3.5" tube. :3d_frown:
Doward
4,245
Alachua, FL
Nothing there, according to the guy I emailed :(
Looks like a 2 piece 3" will be what I have to run, as well. This should be fun to have built, lol.
CPT Furious
Now MAJ FURY!
KDOV
I wouldn't think it would be too bad, just use the stocker for the measurements. I guess the big problem would be convincing them to do it.
antman
632
TN
I don't know about you guys, but my car won't ever see 7200 rpm in 5th. ;)
depends a lot on the rear gear ratio...
if you're getting a beefier 2-piece made, what about the center bearing? it seems to be the weak link in the chain...
looks like fun
if you find a better center bearing, let us know. I went to the junkyard because I needed the part of the driveshaft that goes into the tranny (pulling the tranny, and don't want to drain it). Low milage 90 model and the center bearing was still toast...
