Started this in the general section, but not much info/response... I did not have this issue with the 2JZ-VVTi swap in the '90, so am not sure what's up. This swap, using Aristo engine harness. With the VVTi, I had a 1999 JDM Supra harness. Any ideas on fixing this issue and making it look less retarded?
Thanks,
E
__________________________________________________
Headlight issue
Noticed this recently, but have not even begun to troubleshoot...
The driver's side headlight is on, when I turn on the parking lights. They are both down, but the driver's one is on and lights up the area underneath. Poor man's neon?
I have a set of HIDS I'd like to eventually install, so I'd like to fix this now, before complicating it with another mod.
I did recently replace the switch at the steering stalk, because it was very loose and just the vibration of the car running made the lights go on/off intermittently. I don't remember if I had the same issue before that though.
I do have some extra headlight retractor electronics from other parts cars, but have not tried to swap anything yet.
Car's a '91, w/2JZ... (Running rich and breaking up at ~2500RPM... Still need to troubleshoot this).
Anyone else come across this headlight issue?
Nick M 09-01-2008 12:23 PM
Re: Headlight issue
The 2JZ does that when you install it. It is a glitch in the ISC circuit.
Satan 09-02-2008 06:38 AM
Re: Headlight issue
In the ISC circuit? Is it specifically to using the Aristo ECU? Any workarounds to separating the circuits?
Thanks,
E
Headlight issue
Re: Headlight issue
Re: Headlight issue
