Drilling a hole for EGT.
artorush
Oslo
Hello, I need some opinions for where to best drill a hole(1/8 npt) for a egt sensor. I don't have any possibilities to remove the turbo. Here is a picture with some places I marked: 6th runner, Turbo housing, or after turbo.
Thanks for your help.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
I would never drill into the turbo. keep in mind the turbo is watercooled so you could hit a water channel, oil channel or just fuck up the turbo. To get the most accurate reading you would prolly want to be in front of the turbo, but drilling in cast iron doesnt sound fun, especially considering it could cause cracks in the manifold. I would put it on the elbow after the turbo near the 02 sensor, in fact many aftermarket turbo elbows come with an extra bung already installed.
Good luck!
artorush
Oslo
I've installed full downpipe so there is no elbow anymore. If I should drill there I need remove the down pipe. What about between the downpipe and the turbo?
figgie
Twin Cities, Minnesot-ah
Also remember,
one EGT sensor is the average of all 6 cylinders. And by the time the EGT sensor shows something is wrong temprature wise, the event already took place and probably more than once at high HP/RPM.
So use it as a tool but not as a "Oh shit, something is wrong" meter as by the time the word "Oh shit" comes out of your mouth, you will be lucky to have a working engine much less a hole-less piston.
mirage83
457
Georgia
On my 935 recirc DDP there's a spot already there for an EGT sensor, about 3 or 4 inches down-pipe from the O2 sensor. Don't know if that's the best place for EGT or not, but that's where one would mount on my downpipe.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
6th runner. It is extremely easy to drill in to and tap. I'd avoid drilling in to the turbo at all costs.
artorush
Oslo
lol, true. I've read it's good tool if your going 15PSI with lexus/550cc . I am going to look closer for a hole in the downpipe.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
I would not drill into he turbo. Like Fig newton said, the only way for the gauge to be looked at it a average. If your temp spikes, which I have seen this happen; you have toasted something already.
I have drilled into the downpipe before, and some companies offer a downpipe with more than one bung.
I would avoid drilling the turbo where he indicated ;)
Placing the EGT probe just aft of the manifold/turbo flange pre-turbine is fine. It will give you an accurate average of all 6 cylinder EGT. If you drill the #6 runner, you get one cylinder. If you place it after the turbine (turbo elbo, DP, etc) you will get a lower EGR vs pre-turbine.
figgie
artorush;1301201 said:
I've heard the readings at the 6th runner are the highest temp? Is it true?
hmm
let me copy what I posted in another thread....
myself said:
"If your sentence begins with the following
"I believe...."
pause and think about what you are about to post.....
Others that might lead you to pause before pressing the Enter button...
"I heard...."
"I have a friend...."
"I read on another forum...."
"But so and so did it...."
Guess where your statement falls into ;)
What happens with the "I heard", " so and so" etc is that it is usually never ever true. ;) So what you heard, is not true.
Or asked another way. What makes cylinder #6 hotter than the rest? You are already creating about 800f worth combustion temps on all 6 cylinders.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
I have an EGT laying around that I first decided not to use, however, my newest turbo already has a place for an EGT probe drilled on the side of where the hotside mounts to the manifold.
Seeing how the hole is already drilled and tapped; is there any downside with installing the probe there?
Nope! That is exactly where mine is ;)
artorush
Oslo
figgie;1301202 said:
hmm
Hehe. well said. ;)
dumbo
1,911
Albera, Too Far North
Is that for a WB by any chance?
I would personally drill right before the turbo, on the manifold.
Did you say removing the turbo is not a option? Well than don't drill squat until it is.
isnms
United States of America
Oklahoma
i80.photobucket.com
I use mine for evaluation.
With my SAFR installed I noticed EGT rise, in higher rpm, to ~1550°-1600°F.
When I removed the SAFR and installed the Rebic LC, controls injector duration, EGT remained ~1450°-1475°F in higher rpm.
My probe is pre-turbo in the collector.
edit: both piggyback configurations were tuned to maintain ~11-12 A/F in wot.
photo by jimi87-t
http://www.supramania.com/forums/showthread.php?p=125175#post125175
[thumb]http://i19.photobucket.com/albums/b189/jimichonga/DSCN0900.jpg[/thumb]
[thumb]http://i19.photobucket.com/albums/b189/jimichonga/DSCN0904.jpg[/thumb]
dbsupra90
toonar
indiucky
photo by jimi87-t
how much fuel were you pulling w/ the safr? typically after a point your timing will be higher than wanted and cause higher egts due to airflow scaling.
i use the wb for a/f and egt for timing. i know, here come the pilots... lol
isnms
Oklahoma
i80.photobucket.com
iirc the most I ever pulled was 15% to try for mid 12 afr. I have found some info where I mostly pulled 9% when tuning for a low 11 afr.
I too was able to find a timing problem, miss adjusted CPS, with high egt's.
