artorush;1301123 said:Hello, I need some opinions for where to best drill a hole(1/8 npt) for a egt sensor. I don't have any possibilities to remove the turbo. Here is a picture with some places I marked: 6th runner, Turbo housing, or after turbo.
Thanks for your help.
artorush;1301137 said:I've installed full downpipe so there is no elbow anymore. If I should drill there I need remove the down pipe. What about between the downpipe and the turbo?
figgie;1301139 said:So use it as a tool but not as a "Oh shit, something is wrong" meter as by the time the word "Oh shit" comes out of your mouth, you will be lucky to have a working engine much less a hole-less piston.
adampecush;1301152 said:6th runner. It is extremely easy to drill in to and tap. I'd avoid drilling in to the turbo at all costs.
artorush;1301201 said:I've heard the readings at the 6th runner are the highest temp? Is it true?
myself said:"If your sentence begins with the following
"I believe...."
pause and think about what you are about to post.....
Others that might lead you to pause before pressing the Enter button...
"I heard...."
"I have a friend...."
"I read on another forum...."
"But so and so did it...."
MarkIII4Me;1301212 said:I have an EGT laying around that I first decided not to use, however, my newest turbo already has a place for an EGT probe drilled on the side of where the hotside mounts to the manifold.
Seeing how the hole is already drilled and tapped; is there any downside with installing the probe there?
figgie;1301202 said:hmm
let me copy what I posted in another thread....
Guess where your statement falls into
What happens with the "I heard", " so and so" etc is that it is usually never ever true. So what you heard, is not true.
Or asked another way. What makes cylinder #6 hotter than the rest? You are already creating about 800f worth combustion temps on all 6 cylinders.
mirage83;1301149 said:On my 935 recirc DDP there's a spot already there for an EGT sensor, about 3 or 4 inches down-pipe from the O2 sensor. Don't know if that's the best place for EGT or not, but that's where one would mount on my downpipe.
isnms;1301313 said:I use mine for evaluation.
With my SAFR installed I noticed EGT rise, in higher rpm, to ~1550°-1600°F.
When I removed the SAFR and installed the Rebic LC, controls injector duration, EGT remained ~1450°-1475°F in higher rpm.
My probe is pre-turbo in the collector.
edit: both piggyback configurations were tuned to maintain ~11-12 A/F in wot.
photo by jimi87-t
http://www.supramania.com/forums/showthread.php?p=125175#post125175
[thumb]http://i19.photobucket.com/albums/b189/jimichonga/DSCN0900.jpg[/thumb]
[thumb]http://i19.photobucket.com/albums/b189/jimichonga/DSCN0904.jpg[/thumb]
