BigKO;1581830 said:
In the process, almost finished, just trying to find a place for my oil cooler, so far Ive had to relocate my overflow bottle and my oil cooler, along with trimming the hood latch support. Very not bolt on, and a pain in the ass when you don't expect such tasks to be necessary. Mine however is the cx racing version which looks identical from the pictures.
My friend and coworker has the CX racing kit installed on his car and he did have to relocate the coolant overflow and oil cooler, not sure on the hood latch. Horns are still in the same location as far as I know. He eliminated the stock air box, added a length of bent and polished pipe to the front of the AFM and ran the pipe through the hole in the rad. core support directly below the pass.headlight. The air filter is now located in the recess between the fender and bumper cover (and out of the hot engine bay!). The coolant overflow bottle was relocated to approx. the same location of the stock airbox, and the oilcooler is affixed to the back side of the intercooler itself. I will try to get some pics tomorrow at work when I see him and then post them on here for you to get an idea of how it could go for you.
It is not a 100% bolt on kit, and WILL require a minimal amount of reworking of components, but for the bang for the buck, you can't beat it. When dealing with non-factory parts, you should always take the manufacturer's claims of "bolt-on simplicity" with a BIG grain of salt and be prepared for the possibility of minor modification being necessary.
One thing to note on the BOV included in this kit: the spring is weak and will leak boost even at stock levels. He had to take it apart and find a stronger spring before it would hold up to even 10 lbs. of boost, but now the reaction time is too long and it doesn't open between quick shifts very well, so you may want to look for another bov to use with the kit if you do get it. My 2 pennies...
