Maple191;1860228 said:I love how people litterly burn through their money like that. If you keep doing those launches like that it wont matter what you put in car your just gonna go through it again. Im not trying to sound like a dick but you can only blame yourself.
Orion ZyGarian;1860336 said:I've heard of heavier pressure plates causing crankwalk, despite the car not being made in Normal, IL (DSM joke). As far as burning through clutches, I think you are free to do that as often as you are willing to split the engine/tranny and buy another set to put in haha. There should be a strong enough clutch for you out there that will take your abuse, and it may be expensive; but if you continue your current habits, it is likely cheaper in the long run to get an overkill-sized clutch
The way I see it, you have a couple options:NewGen;1860106 said:It's the black pressure plate not the blue one. Have you still heard of the lighter pressure plates causing problems? One thing i'm very leary about. I was also looking at the HPF Bronze clutch what are your opinions there?
I'll post a picture up of the pressure plate but i'm almost certain it's to far gone. Whatever it is I just need it to last till this winter so 4 or 5 more months.
I agree with this. Either do it right once, or do it wrong repeatedly. Either way, it's going to cost you some money.Orion ZyGarian;1860336 said:I've heard of heavier pressure plates causing crankwalk, despite the car not being made in Normal, IL (DSM joke). As far as burning through clutches, I think you are free to do that as often as you are willing to split the engine/tranny and buy another set to put in haha. There should be a strong enough clutch for you out there that will take your abuse, and it may be expensive; but if you continue your current habits, it is likely cheaper in the long run to get an overkill-sized clutch
te72;1860455 said:The way I see it, you have a couple options:
-put in a new clutch (a cheapish one) that will last you until the end of the year (or however long you need it to), and drive VERY reservedly, or...
-spend the money now for a proper clutch that will handle the torque you're putting out.
Buddy of mine has the same problem. His 7m has to be making around 600whp, and the clutch he is running is a joke. If his tires catch, the clutch fries. If his clutch catches, the tires fry. However, with the tires pouring smoke, he still walks away from me like I'm towing another Supra behind me. :rofl:
Or, you know, drive like you ALWAYS have a cop behind you. That should give the clutch a chance to survive.
On the RPS, you've heard our warnings, up to you to either heed them, or do your own research and come to your own conclusion.![]()
