Drag radials or slicks?
Not trying to make anyone gag or sound gay, but it's been true love since July 22, 1988............
I know I must be gay! But who else is getting drag radials for their birthday?......:biglaugh:
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
I ran Nitto drag radials for quite some time on the street and strip. They last a little over 10,000 miles on the street, in case you were wondering. :naughty:
I handed many a 03/04 cobra their ass on the street on those tires. The look on their faces as an oldschool supra revs up to 5000 rpm and rockets away from them at the tree or stoplight... absolutely priceless.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Im a bit late to the thread, but in your case, you can use any radial you want. What it will come down to is the life of the tire. MT radial= best hooking, but least life. Nitto 555r's = a ton more life, but wont hook as well. I used to run the 555r's they were Ok with the 5speed (had to do alot of feathering for a 1.9 60'), and with the auto they were useless to me when launching with boost. Considerign the power level youre at, the 555s are a good compromise, and should work well.
As far as breakage is concerned, in my experience, somethign in the DS (most likely a u-joint) woudl break first. 1.57 60' on completely stock rear subframe/torque arms, etc and no failures....
Thanks guys..............
Slow66, I'm just trying to get under the 2.50 60'......My car spins so bad right now even feathering it that I refuse to go back to the track without some racing tires. It's useless. I'm hoping to get to around 2.00 60', and lower my 1/8 mile times to 8.00 or their abouts. I won't have them in time to go this saturday night, but next saturday I'm going to go and take my camera. Hopefully we'll get some footage of me spanking a few srt's, and gt's.
IJ, now that you've jinxed us all, I think I can hear my ujoint popping as I type..................:biglaugh:
I just revised my public profile to show what mods I have done to my car. I'm hoping to have the fastest supra in Sumiton, Al.
The only other one belongs to my wife, and there's no way I'm making hers faster than mine.................lol
Jspec7m88
1,583
Nappy City
LOL! Well than it's official!
That's sort of the same deal for me...Now I'm working to be fastest Supra in Shelbyville...and the #1 is a 97 Supra on stock twins...but has a HUGE stall, (Yes, automatic), Carbon fiber driveshaft, FULLY built race-ready transmission and is getting like 1.70 60' on regular street tires...
I'll beat him soon. :icon_evil
lagged
1991 1JZ
new rochelle
you can do a little better on street tires, i had a 2.1 60 foot on street tires.
bfg drag radials next time around for me.
MPF_Supra
Wisconsin
drag radials are nice but sooner or later your rear end will go out or tranny.
i've never had any luck with nitto drag's..seen a buddy run bfg drag's and he's gotten goodluck with them, haven't tryed m/t drag's yet..
Jspec7m88
1,583
Nappy City
MPF Supra:
1992 Toyota Supra Turbo 5spd/ White Package
230hp @ 565ft of Torque.
THAT'ssssssss NICE
^^^^^^^^^^^^^^^^^^^^^ WTF!!!??!!!!?!!!??!!!!
OMGWTFBBQBHGTorQUE?!!!!
That sounds like it defies the laws of physics or something. I made 406 rwhp, and only made 387 ft. of torque. Then again, maybe my car defies physics..........:dunno:
89Turbo
804
Portland
did u put that down in your auto or manual?
automatic the most I dynod was 317 rwhp, 312 torque. I then added a bic ddp, manual transmission, and no boost controller. The first dyno was running 12.5 psi. The dyno where I made 406 was at 18 psi...............lol
Edit: 317 hp= 12.5 psi w/ automatic
....... 406 hp= 18.0 psi w/ manual and bic ddp
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
I pulled several 1.9's on the Nitto's....just fry the shit out of them in the water box :D Take what you think "frying the shit out of my nittos" means, and double it. They love heat.
You can pull a 2.0 on a high performance 10" street tire, too...but this is easier and cheaper.
Thanks boostPSSSHboost. Did you start breaking things when running your drag radials? I doubt that I will break anything major, but just wondering if you did.........lol
drjonez
the motor city
www.4cefed.com
as already stated, the better the traction, the better the 60' and the more stuff you're going to break.
MT DRs are the stickiest you can buy....followed by the BFGs....followed by the nittos. personally, i run nitto DRs on the street and BFG DRs @ the strip. running BFG or MT DRs on the street will lead to a VERY short lifespan (3k miles? if that...).
what you break depends on how you launch...and what trans you have. the first thing to go in a stock auto trans'd car is the auto trans- they can't deal w/the load. in a manual trans'd car, it all depends on your launch technique. slipping the clutch will be far kinder to the trans and the rest of the drivetrain/suspension than a clutch drop....but it will also burn up you clutch rather quickly.
the manual transmissions aren't perfect. the W58 has weak gears and the R154 has the thrust washer issue. your best bet is to baby it if you have the W58 and to run a GOOD oil if you have the R154. i personally have over 200 passes on my R154 and have no issues, thanks mostly to redline heavy shockproof and no speed-shifting.
speed-shifting (flat foot shifting, shifting w/o the clutch, etc.) is a bad idea. the transmissions are not up to it. don't do it unless you like to change the transmission.
the rear subframe is something to be concerned with. if the diff mounting bolts/nuts are even the slightest bit loose, the diff will rock around and beat your subframe to a pulp. the '89+ braces help to hold the subframe together, but the best thing to do is weld the heck out of it.
as already stated, the "strut rods" (trailing arms...) are fairly weak and will bend if your car isn't properly aligned, etc. i personally haven't bent one yet.
the clutch pack diff is plenty strong. the torsen, on the other hand, will blow up if you even think of going to the strip.
no concerns with the driveshaft, as IJ said, it's plenty strong as well...
that's just my $5.....take it FWIW, YMMV, etc.
Cya
628
Columbia, S.C>
I got a 1.6 on a street tire and a doughnut, but Ill probably get flamed because I dont know where my time slip is. I launched at 3-3,500 after trying it at 5-6 and spinning for a sec in the hole.
psifactor
Clearwater, FL
I think you mean a 2.6. I'm going to have to say a 1.6 60ft on street tires isn't going to happen unless they were soaked with vht or something.
I've had great luck with my mt et streets. I have a good amount of passes on them which included heating them up before a run. On the street somewhere over 3k and they still have life left. At the track they are perfect. I can launch it 6k + and they dead hook. I have yet to break anything other than a cracked subframe.
