huntin5L said:I was wondering about the becauseican divorced dp. How do you change the setting. Is there some kind of plate on it to change how you want to run it.
huntin5L said:well doesn't the ddp that because i can have a pipe coming off it that you can use when you want to run the exhaust from the turbo right out to the open
huntin5L said:right that is what im talking about the exhaust from the wastegate. There is a pipe that allows you to run your exhaust from the wastegate right off the dp. Like you said it is loud. How do you change if you want the exhaust from the wastegate out to the exhaust or out to the open. Correct me if my thinking is off.
:withstupishaeff said:you could just get a recirculated DDP, if you want. there are still gains from it, just have him re-route it back to where the dp is horizontal.
-shaeff
