MassSupra89 said:But seriously. someone should turn this into a project/write-up thread.
im stilll doing some research, but i definitley wand to do a project/write p thread on this
nosechunks;1500028 said:Wouldnt it be easier to fit FX-R Projectors with matching HID bulbs to a set of housings for an even lower price? The housing should bolt right in like the sealed beam does.
Why change all of that for no reason? You can get the whole projector/bulb/ballast kit from retrofitsource for about the same amount in USD.
nerfkhat;1500213 said:There are a few of us who have this setup already but it uses our own custom brackets. Rodel and Nick I believe are the only ones with it complete. I only have one side in right now. You can pickup US dot version here of course. The 90mm version fit very will inside of our buckets. I think its a perfect size and will have awesome output. Which from what I read accepts hid very well also.
These work perfectly for us because they are weather sealed so we wouldnt need some kind of housing for it to be in like if you were to use a FX-R or any other HID projector.
Heres a picture..
Nghty89;1500130 said:Do you have a link to any of this information?
