Door locks
gravesdu_99
255
Potsdam
Hey I got a stupid question. I got an 89 supra about a couple of weeks ago. And every time I go to unlock it the alarm goes off. Does anybody know what I might be doing wrong. All I do is put in the key and turn it clockwise to unlock the door. I don't touch anything and the alarm goes off.
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
The simple and effective way to fix this problem if you dont mind not having an alarm is to disconnect the small plug on your hood latch. This will trick the alarm to thinking the hood is always open thus never arming the alarm.
The more complicated way to properly fix your problem is to completely dissemble the door lock, clean it out and fix/replace electrical contacts that sense the key being inserted. See: http://www.supramania.com/forums/showthread.php?t=39358
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
werewolves has it on key.....no pun intended haha
my 86.5 did this and i took my lock apart and bent the contacts back out and never had a problem after that
billspreston01
555
North Carolina
there's a sensor clipped onto the back of the lock cylinder in the doors. When you turn the key it turns and arms/disarms the alarm. I would check and see if that's still on/working.
esteban1490
Finally a Senior
Mar 22, 2007
51
Cedar Falls, Iowa
that was helpful... thanks, i'm always setting my alarm off on my '92
