Does your motor torque alot after your swap?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
After my swap started running my motor seems to torque lot. i was wondering how you guys deal with it? stiffer motor mounts? or do you guys just live with it? my tranny seems to torque and shake lot also... maybe cuz of the motor or could it be cuz my clutch is too strong? any solutions? i was thinking about using bic's stiffer motor mounts and motor dampener if it would help. let me know what you guys think.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Check your mounts, are they worn out? Why do you think your clutch is part of the problem? Does it shake more when used, or between shifts?
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
wait...your 1jz has torque!? Just kidding, do you have solid or stock motor mounts. Maybe something is out out of balance. Check your crank pulley, make sure its tight.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
1 piece or two piece driveshaft?
dampener wouldnt have an affect i wouldnt think on solid motor mounts... and it shakes everything to shit... ask me how i know Lol ;) shifting from 1 - 2 my car jerks but im thinking that has to do either with my bad shifting or the driveshaft bearing being worn out horribly bad
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Check to make sure the bolt on rear turbo is not hitting the heatsheild for the brake lines. If it is it will seem to vibrate alot.
Wayne
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i don't know if it is my mounts but when i looked at them they seems to be in okay shape. i thought it could be my clutch also because i have a competition stage 4 clutch and its only really bad when i take off from a stop or release the clutch after i shift gears... even when i slowly and easily lay off the clutch it seems to torque like crazy. you can see the shifter going back and forth like crazy.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm sure all that is tight and i have stock square mounts with the bic add-ons thats why i was wondering if thats how they should act. i don't remember my 7m doing that.
i have a stock 2 piece driveshaft... are the stock mounts really already that stiff?
Wayne
i'm not sure what you are talking about... never had stock twins i just went straight to big single
tlo86
Jul 24, 2005
3,914
Colorado
i dont have stock mounts i have solids i honestly dont remember what the rubbers were like. curious if your carrier bearing is shot like most of the ones out there, they are aout 270$ or so new
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
if im not mistaken, the center bearing supports the drive shaft. and it sounds like that might be whats wrong. you'll know when it really goes, it just happened in my friends 240 going 70 on the highway. shifter started banging side to side so fast i couldnt catch it to pull it out of gear, ripped both motor mounts, and sheared the tranny mount....not a fun experience.
damn, people post fast here haha. 3 while i was typing this
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
man thats nice... will i get any warnings or signs or will it just happen when it wants to?
SPD TRP
Apr 12, 2005
526
Katy Texas
My bad, the stock twins, one of the bolts will hit the heat shield for the brake lines. Nevermind.
Wayne
