MDCmotorsports;1466850 said:Check the search button. It might be broken.
2 things:dtpBrugal;1466841 said:i was driving todayn my car started smoking out of no where .then it stop .then it stared again. them stop...it kept repeatin this.
dtpBrugal;1466863 said:wheres is the search button located.
Another MkIII;1466867 said:2 things:
First, give us a better description of the problem, and we might be able to offer a suggestion. "smoking out of no where" isn't too useful for us. Second, and one I personally find more important, take a few seconds to type your post in a semi coherent way. In other words, attempt to use capitalization, punctuation, and spelling.
Now to offer some help. Did you have any unusual readings on your gauges? Specifically high temperature. Also, were you able to tell if the smoke had any smell to it?
-AM3
Should we tell him?dtpBrugal;1466871 said:well when i was driving home my car started to smoke out(white smoke) of the tail pipe. there were no warning signs. it just happened and the car had been running good before that. what could have caused it? all the gauges were fine.
dtpBrugal;1466876 said:whats bhg?
dtpBrugal;1466880 said:is not a blown head gasket. i just replaced it with cometic head gasket and arp studs
Another MkIII;1466874 said:Should we tell him?
::bhg::
EDIT: It could be a bad turbo, but given that BHG is so common on these cars in stock form, I would have to say that your odds are about 99.99% that it is a BHG. How many miles on the car?
-AM3
Another MkIII;1466883 said:Did you get the head machined? Torque to 75 ft-lbs?
If you machined the block, did you have it machined with the timing case in place?
-AM3
dtpBrugal;1466887 said:I pay a mechanic to do the jod for me. but also the car been running great.Except for the turbo not spoolin.
No kidding.gaboonviper85;1466889 said:This makes me even more worried about a bhg.
