Does this look right?
prism1
prizmosis jones
May 24, 2006
203
fresno
Ok so i went to put the new clutch bearing in and it fits a lose well loser than stock. Is this normal? Im na with a w58 trans. here are some pics of the new and old bearing.
Thanks for any help.
Dustin:icon_bigg
HommerSimpson
1,067
New Smyrna Beach Florida
If the end of the trans has a colar on it then the throw out bearing needs to have one to that fits nice... it should be greased and slide nice...
I dont know what the end of the trans looks like... but there are mainly 2 kinda throw out bearings... ones that slide up and down colar and ones held in place by fork..
cuel
1,536
Baytown, Texas
That's the cheap replacement throw out bearing assembly from local auto parts. They give out quick, and tend to squeak. They also don't sit quite right on the oem pressure plate. O'Rielly's can get the stock replacement bearing that IJ suggests.
gaboonviper85
3,236
Northeast Philly
the throw out i got from toyota looked so much more beefy......it also needed to be pressed onto the collar.....i put the bearing in the oven at 120 degrees and the collar in the freezer and waited for 20 min and it sliped together pretty easy.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Metal Shrinks when it gets cold, and expands when heated. MMMKAY.
The Bearing and Collar deal with extreme cold and warmth. So that + Ians vice method and you're golden.
prism1
prizmosis jones
May 24, 2006
203
fresno
Im not retarded i understand thermal expansion. I was thinking about the grease inside of the bearing. Wouldn't extreame heat kinda break down the grease kinda premature? anyway a clutch shop offered to push the old one of and the new one on for$15 so ima go that route.
Dustin
gaboonviper85
3,236
Northeast Philly
that bearing has the potential to get hell of alot hotter then 120 degrees....usually bearing grease can handle very hot temps...i could have probably let it sit in 200 degree with no issues.
and what ij said...if its not something you have done before it can screw you up if you dont get it right....but alot of the parts i make at work require tighter fits then that so ive learned how to do it well....vise is easier but the oven was here and the vise was over there kinda thing lol
gaboonviper85
3,236
Northeast Philly
Dustin
thats a rip off!!!!! wtf....greedy bastards....if you came to our shop we wouldnt even bother chargeing you for that shit...takes 2 seconds...fuck that.
id just go to a machine shop i guarantee they do it for free!
prism1
prizmosis jones
May 24, 2006
203
fresno
^^^^lol really i didnt even bother to call anyone else just beuase i thought it seemed descent.lol i guess ill call around real fast in the morning.
Dustin
