I frustrated trying to get my tail lights and instrument panel illumination working. First the tail lights were out, but not the instrument panel - traced that to a rusted and broken wired due to hole in the body behind LR tire.
While taking apart the steering column covers and Driver side kick panel, I lost my instrument panel lights, and now with the tail light wire fixed I still don't have tail lights or instrument panel illumination.
I can get the tail lights, rear side marker lights, and license plate lights to come on by applying 12V to the green wire at the harness that connects it to the fuse block, so all the wiring and lights on the tail light circuit from the fuse block back, including the tail light failure sensor, appears to be working.
Here's the problem: when I pull out the tail light fuse and apply 12 V to the non-grounded side of the tail light fuse socket no lights come on.
And nothing seems to be reviving my instrument panel lights.
Several times I tried different fuses. even tried replacing all the fuses on that block.
I also have a large stray connector near the steering column. It seems to match the O1 connector in the Toyota Electrical Wiring diagram manual, but that one is supposed to be on the passenger side. I can't see anywhere for this connector to attach, can't tell if its important or what it does.
Is it possible that I have a bad fuse block?
Anyone got suggestions, or at least want to commiserate? Thanks.
