Hi Guys
So I purchased this :
http://www.ebay.com.au/itm/POWER-SP...=AU_Car_Parts_Accessories&hash=item3a70ece9cf
After halfway through removing my old turbo I decided to line the new one up for the heck of it. Made the noobish mistake of not checking to see if it would fit BEFORE i started removing the old one as I was told it was complete bolt on and assumed so.
It so happens that the compressor housing is not facing downward like the original ct26 on a 7mgte. At first I thought it was an easy fix, simply rotate the compressor housings , but after speaking to their technical support he figured out that the design itself was incorrect as the wastegate could not move to turn the compressor housing. I'm sure it could work with some modification but this is sold as a bolt on unit. Doubt that an extension of the intercooler piping would work either as the orientation of the compressor housing causes it to hit the mani.
Also , this turbo was purchased for $399 last month but is now being sold at $1399 for some reason. The photos are of the compressor housing in the incorrect position so I dont think they have fixed the problem.
In any case , a warning out there to those that are thinking of buying this as a budget substitute for a stock ct26 - make sure you ask them if this problem is resolved first or look elsewhere.
PS: Id like to say that the return process to this seller was basically pain free and he did refund , however was not happy about the inconvenience caused to me as I had taken a day off work to remove and fit on the new turbo - and this was completely wasted.
