Do I need to install my walbro now???
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
I have just installed a master power 70 , intercooler and pipes,tial bov, maft pro lambda and speed density, aeromotive fpr, but i am still running 440 injectors...do I need to install my walbro before I drive it??? The reason I am asking is because I was told by a reliable source that a factory pump will not give enough pressure for my current setup andlike an idiot I just filled my tank before starting project:/
edit: gonna wait till wends
Sent from my DROIDX using Tapatalk
Smartparts
146
CT
jdmfreak;1691395 said:
I have just installed a master power 70 , intercooler and pipes,tial bov, maft pro lambda and speed density, aeromotive fpr, but i am still running 440 injectors...do I need to install my walbro before I drive it??? The reason I am asking is because I was told that a factory pump will not give enough pressure for my current setup andlike an idiot I just filled my tank before starting project:/
Don't see why you would need to install a walbro now, you're still only flowing 440cc. Seems like a good time as any to install boost controller.
sylquebec
167
Quebec
Same here. But i have the 550 and lex. I'm at the half tank but i dont want to pump so much gaz (30-40 liters) So i will drive the car without pushing it until the thank will be empty. I dont see any problem if i dont boost.
92nsx
2,957
Clearwater, MN
My in-site would help but my Supra dose things no supra should. Cliff notes Im running a stock pump, making 417 RWHP. Again my sup for unknown reasons dose weird (in a cool way) things.
