Do i have a GE or GTE
Grimsta
1,081
Santa Rosa, Ca.
I just picked up a completely disassembled 2JZ, the guy told me it was a GTE, but i saw it and believe its just a GE, whatever its cool, it was $100! You can tell by the valve covers can't you? Just wanted to confirm, the GE has a dip in the middle of the VC for their top fed intake mani right?
Supracentral
10
Does it have a distributor?
2JZ-GTE's don't use a distributor style CPS like the 7M-GTE does.
Grimsta
1,081
Santa Rosa, Ca.
No electronic w/ it, just the engine. But yeah the VCs look similar to the 7M. I gotta bore it out .030 and get forged pistons anyways, so, nothing lost on the NA motor. With the pistons it'll be the same. I'll have to pick up the other things like the cam sensor, ignitor, map, etc.
Cactus, you from Santa Rosa also! Whats ur car look like?
Grimsta
1,081
Santa Rosa, Ca.
Well if Hotscennescy (whatever!) has 500+ w/o squirters i'll take that. So Cactus, you got a 500hp 2JZ Supra and live in Santa Rosa!? Where the hell are you? Unless its stealth as f$&k i've never seen such a thing. PM me your number, i'll give you mine and we'll have to hang out!
Grimsta
1,081
Santa Rosa, Ca.
Yeah i will be putting in forged pistons w/ coating. Still haven't decided on what coating yet though. Should i still put in squirters for road racing?
Feb 13, 2006
69
Ohio
mustangman05 said:
how do you plan to put squirters in exactly?
You can drill the block, it's been done before. I do not believe it's worth your time, forged or not. However if you are going forged, then don't worry about oil squirters.
Grimsta
1,081
Santa Rosa, Ca.
I'll continue to go back and forth, but in the end, since i'm overboring it anyways, i may have the machinist drill and tap it for the squirters anyways. Only thing is then since the NA didnt have the controled "leak" of the squirters, will the oil pump be able to keep up? Or should i shim the 2JZ pump like the 7M pump, to raise the oil pressure
