That was the problem Thanks man!!!!
My third brake light is hacked off so it caused a short... Thanks!!!
87soup;1181282 said:![]()
Is this wrong????
My dash/ parking lights dont work any more and i keep popping my 15amp gauge fuse...
Also STILL NO TAIL LIGHTS!!!!
PLEASE HELP!!!!
Supra-Man18;1226289 said:I did the rewire, but lost the passenger side of my tail lights completely.. no brake lights, no tail lights (hazard and turn signal work).. But the whole driver side works perfect...what can I have done wrong ?
Supra_Shopper;1226309 said:Semi-stupid question, but are you sure they all worked before this was done? The wiring modification does not affect anything side-to side, i.e. if one side works they both should. I would inspect the passenger side lamp sockets for power and trace wiring from there if needed. Is the module unplugged? Double check the wire colors- if you connected to the wrong one, this may be a problem.
