Are the distributors all the same for the '86-'92 Supra NA? Would I be able to get one from a pre'89 motor and put it on a '89 and up motor?
In the Haynes repair manual, it says that these distributors can't be rebuilt.
On the '88 and before models however the distributor driven gear (the little gear at the end of the distributor once you take it out) can be replaced, but on the '89 and later non-turbo distributor unit nothing can be replaced..
I asked this question because the local Toyota dealer has one for like $326 and a rebuilt one from a local autopart store is $216. I thought maybe I can get one from at the nearby salvage yard from a lot cheaper and just make sure it is in good shape. I tend to see a lot more pre '89 than '89 and up models there.
Well thanks in advance.
